Super small coolant leak on head gasket
Old Feb 12, 2011 | 01:46 PM
ewok's Avatar
Default Super small coolant leak on head gasket
Uhm...I'm a little nervous, I'm hoping someone can help.
This morning, I found a very small coolant leak on the drivers side head gasket. Is this an early signs of a failure? Am I approaching a HG replacement? Ugh.
I was hoping to hold off on any major maintenance until my relocation is complete, April 1st but I'll get the HG done if it is suggested.
Old Feb 12, 2011 | 01:53 PM
lipadj46's Avatar
Where on the gasket is it leaking? How fast is the leak when hot? Is there any signs of coolant in the oil? If it is a slow external leak just stay on top of the coolant level and top off as needed. Check coolant level every morning and pay attention for overheating and coolant smell. You may want to add some coolant dye to make a leak more noticeable.
Old Feb 12, 2011 | 02:00 PM
ewok's Avatar
Hi Lipad,
front most outer side, right on the corner, of the gasket on the drivers side. No signs of coolant at all in the oil. I check the oil once a week. Will keep an eye on it - no coolant smell as of yet.
I like the idea of dye - good suggestion!! Thanks!
Thanks again!
Old Feb 12, 2011 | 03:30 PM
jkid's Avatar
Make sure the throttle body hoses and gasket are not leaking. That is more likely to leak and it would drip down onto that area.
Old Feb 12, 2011 | 06:43 PM
tnridge's Avatar
8th Gear
There are two small coolant lines there also at the throttle body. Do they take orings or a gasket. They are hooked to a plate there? Anyone can tell me what they are called so I can order them. I have no idea and need to know.
Thanks
Old Feb 12, 2011 | 06:53 PM
willrok13's Avatar
The throttle body heater hoses use hose clamps, the plate itself has a gasket. I'm not sure what exactly you're asking, no o-rings exist on the throttle body heater.
Old Feb 12, 2011 | 09:28 PM
unimoged's Avatar
See that you are located in New Hampshire. With the weather being extremely cold, many small leaks can develop in a cooling system. I would bet it is the hard plastic lines going to and from the heater plate on the lower part of the throttle body.
Just keep an eye on your coolant level and don't let it get too low, since air will get in and around the thermostat, which is external, and cause it to overheat.
Wait till the spring and see if it get worse. I am sure it is not your head gasket.
Old Feb 13, 2011 | 09:41 PM
ewok's Avatar
Thanks all!
Berryman
Oct 22, 2012 08:03 AM
Sunny side auto
May 29, 2011 03:57 PM
HE_CPT
Oct 6, 2010 02:21 PM
Rover Chris
Feb 26, 2009 11:07 AM
ccvalentino
Jan 6, 2008 08:11 AM
