Coolant Leaking
Coolant Leaking
I had a slow leak of coolant and had the head gasket, water pump replaced. Today, when driving it, the coolant was overflowing thru the reservoir hose and it sounded like the coolant was getting stuck at the thermostat...
The landy has been running fine for two weeks since leaving the mechanic...
is this problem a bad thermostat that is not opening up or could it be the water pump that is not moving the coolant around?
aguison
11-18-2012 05:15 PM
