Coolant Leaking
Old Mar 5, 2009 | 05:31 PM
asikuy's Avatar
Default Coolant Leaking
I had a slow leak of coolant and had the head gasket, water pump replaced. Today, when driving it, the coolant was overflowing thru the reservoir hose and it sounded like the coolant was getting stuck at the thermostat...
The landy has been running fine for two weeks since leaving the mechanic...
is this problem a bad thermostat that is not opening up or could it be the water pump that is not moving the coolant around?
Old Mar 5, 2009 | 05:35 PM
It could be either, take it back, dont wait, take it back tommorrow as youi by law have a 30 day warrenty on all work that was done.
You also have whatever warrenty the parts came with, usually 90 days, sometimes more.
Old Mar 5, 2009 | 06:57 PM
okdiscoguy's Avatar
Could just be an air pocket heating up and pushing it out, Take it back ASAP before you overheat it and kill the engine...
rally1
Feb 22, 2022 06:22 AM
Stashf
Jun 9, 2007 07:05 AM
allstarbiker592
Sep 25, 2006 08:47 PM
r1pilot
Jan 26, 2006 12:15 PM
