Coolant level
Old Mar 9, 2018 | 03:02 PM
zuke's Avatar
Default Coolant level
On my 04 I have a weird thing with the coolant level. It will go down way below the normal level about even with the nipple that goes to the TBH . If I fill it up it will get pushed out by pressure through the overflow onto the frame rail. The main hose does not get hard with pressure and its been doing this for the 2 years that I have had it. All my others run about 1 inch below the full line . Any ideas what the issue is?
Old Mar 9, 2018 | 03:08 PM
Friday Night Disco's Avatar
I have thoughts:
1. You have an air pocket in your heater core
2. T-stat is not opening and closing properly allowing back pressure
3. You have a clog in one of the hoses, possible heater core
Old Mar 9, 2018 | 05:26 PM
mln01's Avatar
Buy and install a new reservoir cap. About $15 at any auto parts store.
Old Mar 9, 2018 | 09:19 PM
xsramo's Avatar
I’m battling a similar, if not the same issue. I bypassed the throttle body heater the other day thinking that would solve it but it still does the same thing as you mentioned. My disco doesn’t leave any drips on the ground and no visible signs of coolant leaking. Coolant level will drop to the same place every time I fill it up. Will be curious what you find out.
Old Mar 9, 2018 | 10:05 PM
number9's Avatar
2nd the cap. And bleed the system after you do the grueling install.
Old Oct 15, 2019 | 12:24 PM
mr. choodles's Avatar
Hey have you ever found out what caused your coolant level to drop to the same level all the time? I have the same issue; not sure what is causing it. Thank you! --mc
Old Oct 15, 2019 | 06:10 PM
zuke's Avatar
It was an external HG leak at the rear of no. 7
satcal0
May 3, 2009 01:54 PM
ryanljcom
Sep 18, 2008 12:06 PM
MikeLi
Sep 18, 2008 10:33 AM
bigugly82
Aug 22, 2007 08:04 AM
ferrelltodd
Dec 18, 2005 03:33 PM
