Coolant in oil
Old May 2, 2009 | 03:34 PM
paultfh's Avatar
Default Coolant in oil
A friend of mine has an 02 D2 with a 4.0 (edit). It overheated on him and he drove it about 5 miles home.
The thermostat was the culprit however now the oil is a milkshake.
Figuring it was a head, I did a compression test on each cylinder but all 8 tested at about 150 psi and held.
Where else could the coolant and oil be mixing?
Thank you
Old May 2, 2009 | 03:39 PM
paultfh's Avatar
Also it's running like trash. It sounds like it's missing however the check engine light is not coming on.
Old May 2, 2009 | 03:43 PM
First, do not restart the engine, which if stock is a 4.0.
Second, lets don't do this third hand, your friend stands a real good chance of loosing that engine, especially after driving it over 5 miles while overheating, good chance he has dropped a sleeve and if that is the case, the engine is junk.
Consider having him PM me his tele number so we can talk.
Old May 2, 2009 | 05:59 PM
He either blew a head gasket your dopped a sleeve.
eodkuhn
Oct 15, 2018 09:44 PM
ZMonet
Jun 24, 2016 04:00 PM
Rufflyer
Mar 22, 2015 10:13 AM
skeester
Dec 30, 2011 05:42 AM
