Coolant Pressure test - questions
on
If you're not losing any coolant I'd call it good at 3-4 hours. If you're losing coolant and cant find the source it's time to add UV dye, go for drive to complete a few heat cycles and then retest after dark with a nice UV flashlight. Pull spark plugs if you can't find anything external.
I don't even use a good UV flashlight, I use a cheap one meant to find where animals have peed on the carpet.
