Coolant Pressure test - questions
Old Oct 19, 2023 | 08:37 AM
keninnc's Avatar
Default Coolant Pressure test - questions
While doing a coolant pressure test what is the normal time to come back and check for leaks - assuming you don't see any in the first 5 minutes or so.
And, how long should it hold that pressure, it it reasonable to be able to hold it for 3-4 hours?
Old Oct 19, 2023 | 10:59 AM
Richard Gallant's Avatar
On a cold pressure test, it should pretty much hold until you release it. It will drop slowly but it should hold over night
Old Oct 19, 2023 | 01:06 PM
Extinct's Avatar
I have held overnight as well.
Old Oct 20, 2023 | 09:14 AM
PickleRick's Avatar
If you're not losing any coolant I'd call it good at 3-4 hours. If you're losing coolant and cant find the source it's time to add UV dye, go for drive to complete a few heat cycles and then retest after dark with a nice UV flashlight. Pull spark plugs if you can't find anything external.
I don't even use a good UV flashlight, I use a cheap one meant to find where animals have peed on the carpet.
Hamza89
LR2
41
Apr 10, 2023 08:21 PM
mwindth
Jan 7, 2010 11:15 AM
david1289
May 22, 2009 10:18 AM
tailchaser0527
Jan 14, 2008 07:32 PM
suveer
May 9, 2007 08:20 AM
