Coolant question
Old Nov 3, 2022 | 10:14 PM
sirapplesauce's Avatar
5th Gear
Default Coolant question
I had a coolant flush today at a local mechanic shop and when i got back home and read the receipt (i should have done that at the shop but i was distracted from my kid) i realized that the mechanic only put two gallons of the PEAK OAT Pink stuff that is already 50/50. which means he filled the rest with water. Even my reservoir looks like it is straight water barely any pink in it. Should i be concerned ? or is it okay ?
I definitely plan on going back tmrw because it does not sound right (there is a reason the 50/50 has a big sign saying DO NOT ADD WATER) right ???
Old Nov 4, 2022 | 05:58 AM
redwhitekat's Avatar
2 gallons sounds about right when flushing out coolant, that's all it should take, even on a flush you will not get everything out, so 2 gallons is good
Old Nov 4, 2022 | 08:02 AM
mollusc's Avatar
RAVE says 12L to refill the V8 cooling system. That's a little over 3 gallons.
Old Nov 4, 2022 | 08:22 AM
Alex_M's Avatar
Some coolant always stays in the block.
You've got some flexibility depending on your regions climate as well. Where I'm at I usually do 1 gal/antifreeze and 1.5 to 2 gal/water.
There are antifreezes though that do not take water. I doubt that pink stuff is among them, but I don't know enough about it to say for sure that it's not. Also generally not recommended to mix different types of antifreeze, ie. The pink with whatever was still left in the block. Probably dexcool, maybe green. I run green in pretty much everything. That said, since it lists 98 and up Disco on the front, I'd say it's probably ok to mix with dexcool even if it's not optimal.
Old Nov 4, 2022 | 10:02 AM
mollusc's Avatar
Would the block really retain about 1/3 of the capacity of the entire cooling system? Seems unlikely that it would be that much.
Old Nov 4, 2022 | 11:18 AM
yes everytime i did a coolant change usually 2 jugs is enough
Old Nov 5, 2022 | 09:54 AM
JohnZo's Avatar
Default One gallon in block
About 1 gallon stays in the block. I measured into a dry system, then draining out of the radiator. It makes sense if you think about the size of the block and coolant jacket volumes. Works out great if you use concentrated glycol vs pre-mixed.
lazerbrains
Oct 18, 2018 06:40 AM
DailyDisco
Dec 6, 2016 04:48 PM
za105
Aug 4, 2015 04:19 PM
MONEYMIKE
Aug 20, 2013 12:31 PM
lrjon
Apr 30, 2012 06:41 AM
