Coolant Reservoir Leak?
Old Apr 27, 2008 | 03:46 PM
jkid's Avatar
Default Coolant Reservoir Leak?
Eversince I bought my Disco the coolant has been steady at about an inch below the max fill line (where the tank is sealed). Lately I've been topping it off so that it is right at the max line, butit will not stay there. The coolant always ends up at an inch below and stays. The only thing I can think of is when I top it off the coolant will leak though the tank's seal when it expands until it gets low enough to stop and stays steady. I don't see and coolant leaks though, are there any other possibilities?
Old Apr 27, 2008 | 04:08 PM
Phototone's Avatar
Default RE: Coolant Reservoir Leak?
I read where there was a problem with some coolant reservoir tanks. Is yours black, or completely white (semi-transparent)? The ones that are partially or all black had the problem, IIRC.
Old Apr 27, 2008 | 04:15 PM
jkid's Avatar
It's semi-transparent, yellow really. Maybe it was white at one point, I don't know.
Old Apr 27, 2008 | 04:34 PM
Sounds like a leak in the reservoir, if you are using Dexcool you will wantto fix it ASAP.
Old Apr 28, 2008 | 05:23 PM
jkid's Avatar
Looks like there is a hose leaking near the throttle body. Not sure howthat works because I thought it was all circulated by the pump, but it must stop when the coolant gets low enough.
Old Apr 28, 2008 | 05:56 PM
You need to do a coolant pressure test and verify where the leak is, then fix it. If it is the t/body heater unit get a new replacement gasket kit.
Old Apr 28, 2008 | 06:56 PM
jkid's Avatar
There's no doubt that it's leaking there. It looks like that goofy rubberhose to rubber hose connection is leaking in the return line. How did they expect that not to leak? [sm=smiley24.gif]
Old Apr 28, 2008 | 06:59 PM
Only needs to not leak until the warrenty is up dont ya know.
ZMonet
Jun 24, 2016 04:00 PM
aguison
Nov 26, 2012 08:33 AM
aguison
Nov 14, 2012 07:51 AM
