Coolant System Overhaul: Best Practices?
Old Apr 5, 2024 | 03:33 PM
mln01's Avatar
I'm surprised no one has commented that you apparently have Dexcool in your truck. The consensus here and in other forums is to avoid Dexcool.
Old Apr 5, 2024 | 10:21 PM
SouthByWest's Avatar
Is there really a consensus? Or more like a forever war?
Old Apr 9, 2024 | 03:04 PM
Brandon318's Avatar
I would 100% get an aluminum expansion tank. I had a brand new tank (Behr) split at the seam one day driving. Miraculously it happened as I was pulling into my driveway. How the heck that worked out, no idea, but thankful.
Avoid Dexcool as others mentioned. I use BMW's blue coolant since it's formulated to specifically work with aluminum blocks. I'm sure others are great too. BMW's is re-branded Zerex, but the BMW one isn't expensive, so I just get that.
Old Oct 11, 2024 | 04:36 PM
MyOldCars's Avatar
I am using orange-colored coolant, Prestone, I think it's for GM engines. I am not even sure, I think the previous owner had that in there, but... Am I doing something wrong? What's "Dexcool"? Lots of engines are built on aluminum blocks these days, not just old Rovers... Please clarify.
Yeah, went down to the garage, checked it out - it's Preston DEX-COOL for GM vehicles, orange stuff. Now, I had a serpentine belt brake on me a few months ago. The motor overheated a bit, I lost some coolant, and ended up replacing the temp sensor, bottom line is, my orange Preston Dex-Cool is practically new. I thought this was the correct type of coolant for this truck... I guess I was wrong...
Is it something that has to be addressed ASAP or can this wait a few more months?
Old Oct 11, 2024 | 06:58 PM
Extinct's Avatar
Dexcool is mostly only a problem on cast iron engines, less of an issue with all aluminum engines and cooling system. No downside to changing to conventional coolant.
Old Oct 12, 2024 | 06:57 PM
Discorama's Avatar
I avoid Dexcool, since I am using Land Rover XLC.
Old Oct 12, 2024 | 09:22 PM
MyOldCars's Avatar
I have already learned, that most people in LR world are avoiding Dexcool. So, I now realize - that's what I have in my cooling system, and it's pretty new and fresh. Should I dump it as soon as possible as in an emergency, or should I just run it for a while and switch to something else later? Is Dexcool known to actually damage our engines or headgaskets somehow? That's what I am trying to ask at this point.
Thanks.
Old Oct 13, 2024 | 01:22 AM
Discorama's Avatar
It's not an emergency having Dex-cool in the system. It's even claimed that Dex-Cool is compatible with our engines: https://www.fcpeuro.com/products/lan...-zxel1#fitment
Dex-cool and LR XLC are both OAT coolants, but LR XLC is the better choice because the additives are specifically made for Land Rover engines, while Dex-cool is made for US-cars. That's why I prefer LR XLC.
me 2
Mar 23, 2022 01:53 PM
ROVERRACER
Jan 9, 2015 08:17 AM
Chicago KC
Mar 21, 2012 07:07 AM
samue23
Mar 1, 2012 05:49 AM
blcp86
Sep 15, 2009 08:52 PM
