Coolant Tee Bleed Screw Alternatives?
Old Jul 12, 2016 | 01:01 PM
discorey's Avatar
Default Coolant Tee Bleed Screw Alternatives?
I stripped the bleed screw on my newest coolant tee.
Anyone have a working alternative tee made from something a little sturdier than the plastic?
Has anyone had luck using the brass coolant tee bleed screw after stripping the plastic bleed screw?
Thanks for any suggestions.
Old Jul 12, 2016 | 01:30 PM
discorey's Avatar
Also considered using one of these: https://www.amazon.com/Docooler-Temp...DH5NW1CY4WK909
Thought about putting it inline slightly ahead of the current coolant tee, then epoxy the bleed screw into the current tee.
Anyone tried that?
Old Jul 12, 2016 | 04:00 PM
dtmbinb's Avatar
Use the brass one. Be careful not to over tighten. The o ring is what makes the seal.
Old Jul 12, 2016 | 04:43 PM
Frank4's Avatar
BMW Vent Screw. No more that $10 and its brass.
Old Jul 12, 2016 | 05:19 PM
number9's Avatar
BMW PN 17111712788, stock/dealer part is plastic as well. Brass is aftermarket upgrade. Goggle PN for buying options.
Here's one link...Category
Old Jul 12, 2016 | 05:38 PM
discorey's Avatar
Thanks everyone. I just ordered the brass one and that 32mm connector. Figure that out of the two, I'll eventually get something that doesn't leak.
Old Jul 12, 2016 | 08:47 PM
Frank4's Avatar
Huh, good to know. Thanks.
Old Jul 15, 2016 | 04:06 PM
discorey's Avatar
So far, it looks like the brass screw is not leaking. It leaked at first, but it was because I was afraid of tightening it too much.
Evan5291
Jul 27, 2017 10:04 PM
mvalamiko
May 31, 2013 02:34 PM
mossmanxjt
Sep 3, 2012 04:19 PM
03discoman
May 9, 2010 09:46 PM
JAC
Oct 1, 2009 04:02 PM
