Coolant temp & Oil pressure gauge
Old Nov 8, 2014 | 04:15 PM
DustyLBottoms's Avatar
Default Coolant temp & Oil pressure gauge
Finally installed my oil & coolant gauges.
I'm getting 22psi at hot idle with Motorcraft full synthetic 5w40 diesel oil, and a brand new oil pump.
Also:
Old Nov 9, 2014 | 09:24 AM
MetalMarine's Avatar
Awesome. I will be doing the same thing next month. Might add the voltage gauge too.
Old Nov 10, 2014 | 02:14 PM
trialrun's Avatar
purrty, what was involved, i'd like to do the same?
Old Nov 10, 2014 | 05:21 PM
OffroadFrance's Avatar
Nice job. 2 best and most important gauges you could have picked.
Old Nov 11, 2014 | 10:02 AM
Amazon.com: MaxTow Water Temperature Gauge: Automotive Amazon.com: MaxTow Water Temperature Gauge: Automotive
Amazon.com: MaxTow Oil Pressure Gauge: Automotive Amazon.com: MaxTow Oil Pressure Gauge: Automotive
Amazon.com: GlowShift Universal Dual Gauge Console Dash Pod: Automotive Amazon.com: GlowShift Universal Dual Gauge Console Dash Pod: Automotive
Amazon.com: GlowShift 34 MM or 1 5/16 Inch Water Sender Attachment: Automotive Amazon.com: GlowShift 34 MM or 1 5/16 Inch Water Sender Attachment: Automotive
Everything you need comes in the above links, except for 3 "add a circuit" fused adapters, that way you don't need to splice anything. I would also get some wiring loom to make it look factory.
Old Nov 11, 2014 | 12:01 PM
potxoli's Avatar
this is such a cool project. Where does the oil pressure sensor connect?
Old Nov 11, 2014 | 12:13 PM
drowssap's Avatar
you can tee off your original sending unit or use a sandwich adapter between the filter and the block
Old Nov 11, 2014 | 12:29 PM
There's a port right next to the stock oil pressure switch port on the timing cover. You'll need an adapter to make it work, M20 to ⅛ NPT.
Old Nov 11, 2014 | 12:31 PM
Alex_M's Avatar
Saw this on reddit too, looks great man. Similar temp gauge setup to mine. I also just noticed, your coolant isn't green. It's red. What kind of coolant are you running?
Old Nov 11, 2014 | 12:33 PM
I had originally wanted to go with the tee, however you need a low-rise tee in the correct size (m20) which was hard to find. I don't like the sandwich adapters in principle, preferring to keep a stock look, and also wanted to prevent my filter from sticking out any further, since I use the larger filters and it sticks out enough already.
