coolant temp sensor
Old Jan 14, 2008 | 01:05 PM
louied's Avatar
Default coolant temp sensor
Hello
Just wondering if anyone has ever replaced a coolant temp sensor in a disco II.
If so can you help me out and let me know where it is located. I need to replace it. Is this a difficult job should I attempt to do it on my own or take it in I already have the part.
I have owned my disco for about 2 years now and have done small repairs here and there nothing mager.
Thanks
Old Jan 14, 2008 | 07:54 PM
okdiscoguy's Avatar
Default RE: coolant temp sensor
D2 is different from mine, but I think you should get a workshop manul (rave cd) before starting something like this. After replacing, you will need to bleed the system...
Looks like you need to pull the alternator. Pull the plug and remove the old one. Put some loc-tite on the new one, install it and put the alt. back on. Then top off the coolant. Not sure if this sounds like what you are up for, or not.
I am just going off the manual. Mine was a lot easier in my D1...
Old Jan 14, 2008 | 07:56 PM
arihillfarm's Avatar
6th Gear
At the front top of the eng. in the middle. Look under the two throtle cables. In the intake manifold.
Old Jan 16, 2008 | 10:24 AM
louied's Avatar
Thanks for the info. I'm gonna give it a shot. I did order a workshop cd rom so we will see how that go's
Thanks!
ValveCoverGasket
Mar 12, 2012 07:30 PM
tibyABv6
Nov 17, 2011 08:26 PM
collin Barrows
Aug 8, 2011 09:33 PM
willlane
Jan 4, 2008 09:05 AM
