?Coolant Temperature Sensor vs. Radiator Temperature Sensor in D2
Does the ECU use the resultant temperature differential to make decisions does anyone know -- the delta of hot to cold coolant -- or is setup pretty stupid and the CTS is goto for most everything which would explain a) why I never knew the RTS existed until I replaced the radiator b) scant mention of RTS in forum (vs *much* info re CTS)... equivalently, is RTS for some trivial scantool monitoring stat that isn't relevant to the real-world biz of running these beasts? Endless thanks -- couldn't run my rover without y'all. happy new year.
The RTS is specifically for use by the Secondary Air Injection system to determine when to activate that.
Best4x4 (01-10-2020)
SALTYLRD21999
11-26-2013 07:48 PM
couzteau
03-14-2012 07:32 PM
