?Coolant Temperature Sensor vs. Radiator Temperature Sensor in D2
Old Jan 9, 2020 | 05:57 PM
tres_amigos's Avatar
Default ?Coolant Temperature Sensor vs. Radiator Temperature Sensor in D2
What is the difference between the two functionally? On a 2004 Discovery 2, the CTS is on top of the engine by the alternator, the RTS is by the lower hose on the radiator. Thanks to all.
Old Jan 9, 2020 | 06:32 PM
Sixpack577's Avatar
The top is after the thermostat.
The bottom is after the radiator has cooled the coolant...and the gauge is notorious for being inaccurate.
Old Jan 9, 2020 | 08:00 PM
Got it--many thanks.
Does the ECU use the resultant temperature differential to make decisions does anyone know -- the delta of hot to cold coolant -- or is setup pretty stupid and the CTS is goto for most everything which would explain a) why I never knew the RTS existed until I replaced the radiator b) scant mention of RTS in forum (vs *much* info re CTS)... equivalently, is RTS for some trivial scantool monitoring stat that isn't relevant to the real-world biz of running these beasts? Endless thanks -- couldn't run my rover without y'all. happy new year.
Old Jan 10, 2020 | 05:12 PM
Jason Feuerstein's Avatar
The RTS is specifically for use by the Secondary Air Injection system to determine when to activate that.
Old Jan 10, 2020 | 08:01 PM
thx so much!... was buggin' me
Enjoy
humroot
Aug 2, 2017 08:13 AM
SALTYLRD21999
Nov 26, 2013 07:48 PM
Colorado David
Jun 6, 2013 10:42 PM
Altech
Dec 5, 2012 02:21 PM
couzteau
Mar 14, 2012 07:32 PM
