Cooling Fans
Old Aug 3, 2008 | 07:28 AM
imgoingup's Avatar
6th Gear
Default Cooling Fans
In my journey to improve my 1999 Disco series I I've noticed that the supplemental cooling fans do not run when the AC is turned on. How common is it that both fans fail? What would be the procedure to test the fans before I invest in replacing them?
Thanks for the help!
Old Aug 3, 2008 | 08:57 AM
Default RE: Cooling Fans
First check and make sure they turn freely, then check the fuses, then check with a test probe for power to the fans.
You could have one of the 2 sensors, a/c or temp, that are not working.
wilson96rr
May 31, 2009 10:07 PM
Rfactor
Jan 21, 2008 10:17 AM
jmt
Dec 23, 2007 06:16 PM
stanigu
Aug 23, 2007 09:39 AM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
