cooling suggestions?
hey guys, ive got a 97 d1 with around 140k miles on it that runs a little warm on long trips or if the ac is on for awhile if it's around 90 plus outisde. t-stat and water pump are only 2 years old and the system seems to be holding coolant fine. i've flushed it regularly but it hasn't seemed to help much. from what i've read i'm thinking the radiator might be clogged so any suggestions on a good replacement?
RE: cooling suggestions?
the fan clutch seems to be working fine. the electric fans don't start for a while but they still run after i turn off the vehicle sometimes so i'm not sure if they are working properly.
i have cleaned the radiator off pretty good after getting her dirty and i've noticed some parts of the coil are bent. not majorly and only in a couple of places. like i've picked up a rock or two here and there.
thanks for the fast repsonses guys, and i appreciate the advice!
Also possibly overcharged AC system , have a shop check your system pressures, LOW SIDE no lower than 30 psi (at 2k RPM)
HIGH SIDE no higher than 250 psi on a hot day, and air flow is critical . also make sure no junk is jammed between the condenser and rad.
All important posts to look at
on
ORIGINAL: okdiscoguy
98roverguy- when did you get aJeep? (traitor)
I figure one hand washes the other! [sm=patriot.gif] (Finally got a chance to use this on a Land Rover forum! ha!)
flygirl92
04-26-2007 06:54 PM
nickydean
07-20-2006 09:39 AM
