Cooling system help
Old May 6, 2018 | 09:13 PM
  #61
redwhitekat's Avatar
I will try that now with the black britpart
Old May 6, 2018 | 09:54 PM
  #62
Ok seems to be opening at 190 I can see through the top hole and the bottom hole at 195
Old May 6, 2018 | 10:14 PM
  #63
Best4x4's Avatar
Well it's not a stuck thermostat then. If it opens it opens, so I'd rule that out.
Old May 7, 2018 | 07:54 AM
  #64
Well put in the lucky 8 this morning temps rise to 215 at times
put in the Atlantic British again stays at 204-206
something flow related is happening with the lucky 8 stat
Old May 7, 2018 | 07:55 AM
  #65
I think at this point I'll stick to the Atlantic British stat
I'm really tired of draining coolant and all that crap stuff
Old May 7, 2018 | 07:59 AM
  #66
Saturnine's Avatar
Did you ever bypass the heater core? Just because the hoses are the same temps in and out doesn’t mean it isn’t clogged.
Old May 7, 2018 | 08:33 AM
  #67
I'm not worried about the heater core I flushed it lots of heat
the Atlantic British stat drops my temps immediate
black britpart stat increases my temps
Old May 7, 2018 | 09:20 AM
  #68
Best4x4's Avatar
Poor coolant flow as you rev up more = water pump spins faster, and so does the fan clutch/fan. The britpart stat opens so it’s not a faulty stat (and britpart makes an OEM temp stat. Gotta read the actual F/C stamped on the thermostat itself to confirm). You’re gonna have some air in the system especially after just quick swapping parts. A complete cool down is overnight, when the system will automatically burp itself, then you check the bleed screw and remove what is left.
If you had a pyrex glass tube (like me) you could actually see your flow/bubbles.
Radiators are cheap, fan clutches/fan blades are cheap, but a HG job or new engine is not.
Old May 7, 2018 | 09:26 AM
  #69
Friday Night Disco's Avatar
Curious if you are hearing any water fall or gurgling sounds from inside the cabin?
Old May 7, 2018 | 10:39 AM
  #70
The stat is not good like I stated in previous comments
with the Atlantic British stat temps are ok
with the lucky 8 they are not ok
no water sounds from heater core
but I will Check level in the morning
