Cooling System Issue
My truck is acting like it has a bad thermostat.
The Water pump is circulating coolant, I can see it in the reservoir, and the heat is working perfectly.
I've drained it a few times while putting in a new thermostat, but I just boiled the old 180, and it opened up right at 180.
I drained the coolant from the bottom of the radiator and was able to pull air through the radiator with a vacuum.
I have the tube out of the thermostat that is vertical going up to the coolant elbow and the radiator, the smaller 45 degree tube to the water pump.
I am not sure how to proceed aside from drain it again, and put the tested thermostat back on.
Can anyone think of anything I am missing? It's like there is something obvious, but I am just not seeing it. The Engine temp sensor is new, radiator relatively new, and the thermostat should be working.
All I can think of is obstruction in the lower radiator hose.
You could be getting air sucked in through a bad coolant reservoir cap, bad throttle body heater/connections, or bad bleed screw.
Air in the system is going to make everything funky.
Consider the inline thermostat mod, plugging (just temporarily!) the coolant overflow tube, and duct taping or otherwise double-sealing the bleed screw.
Remove and plug the throttle body heater+tubes for a test, too.
Also, check your oil level just in case you are super low.
Add in Water Wetter to pure distilled water as a coolant temp test.
Check fan speed/connections for radiator.
Consider adding a $5 heat sink around your oil filter.
Test your coolant for exhaust fumes (just in case).
Check your air flow through radiator. Discos have some interesting air shrouds next to the headlights, and verify upper+lower main fan shroud is all intact and properly directing airflow.
Maybe consider removing the belly pan tray?
My recent cooling troubles were due to 3 bad thermostats I received from Atlantic British and lucky 8
so im not sure if there is a bad batch of ****ty parts going around or what
my Tstat also opened in a pot of water but it did not open on the truck so I was running 220 degrees
also on a side note just purchased a wiper motor from rock auto and guess what doesn't work
had to reinstall my old one
I'm not liking the parts quality these days
Thanks guys. I tried my old coolant res cap no difference. When it is cool, going to try to inspect the top of the reservoir/bottle.
also, find another thermostat. Or I may just do inline.
I'm just going to do the inline mod if the Coolant Bottle checks out ok.
You've done a **** ton of work on this engine, hate to see these issues. Hang in there. You've had the cooling system open a bunch it looks like. Tighten all hose clamps again, inspect all hoses, double check belt routing. When u do the bleeds, front of truck raised and res bottle raised too. Something somebody says is gonna get this thing right...
If the pressure tests is good, there are no exhaust gases in the coolant I may do the thermostat mod, because at that point it is that or the water pump, and I can see the water pump is working.
