A Cooling venture with graphs.. No Magic results like most
Old Jul 30, 2022 | 12:52 PM
  #31
Richard Gallant's Avatar
@jastutte The fan clutch is only controlled by temp - so if it gets hot under your hood it engages even at highway speeds. Most start to lockup at around 170F (180 to 190) engine temp, the clutch picks up waste heat from the rad for the most part to activate, add A/C and a hot humid day and higher RPMs under load it will engage
Old Jul 31, 2022 | 08:31 PM
  #32
Sandman614's Avatar
Confirmed, the nail in the coffin is the Temperature Sensor giving incorrect readings. I found the original MEK100160 sensor, cleaned it up, tested it with boiled water, reinstalled it, topped off coolant and went for a ride. Ambient temps were 75-80F and raining, I will make another run in the ridiculous heat tomorrow..
Note I lowered the minimum temp of the graph to 170F
Factory MEK100160 sensor
Delphi sensor
Old Jul 31, 2022 | 08:42 PM
  #33
RA122125's Avatar
Banned
That's gotta feel good to have figured out! Nicely done!
Old Aug 1, 2022 | 07:22 AM
  #34
Sandman614's Avatar
It does but it's ridiculous that 2 other sensors are completely wrong.. Blatant Chinese knock-offs of things work better than these "aftermarket/OE quality" parts. A Temp sender isn't a crazy new device, it shouldn't be that hard for these companies to get right.
Old Aug 1, 2022 | 08:01 AM
  #35
Sandman614's Avatar
I just started digging into BMW 4Pin ECT Sensors to compare, trying to matchup which BMW used the Motronic 5.2.1 ECM.
WALKER PRODUCTS 2111053
NTK EF0082
CTS-066
BMW > 1997 > Z3 > 2.8L L6 > Cooling System > Temperature Sender / Sensor
tanman1234
Feb 12, 2022 01:02 PM
redwhitekat
Aug 2, 2021 05:50 AM
CollieRover
Jun 18, 2020 01:05 PM
Luckyjayb
Feb 19, 2017 04:36 PM
austinlandroverbill
Dec 22, 2015 08:14 AM
