Is this the correct way to install Terrafirma spring retainers?
Old Feb 17, 2017 | 02:36 PM
Jeff Blake's Avatar
Default Is this the correct way to install Terrafirma spring retainers?
See pic. I have the retainer between the shock and spring. The only other way I could see it going in is the retainer on top of the shock.
Also, the retainers came with allen bolts and locknuts, but the axle already has a captive nut, so I choose to use the original bolts (with no nut)?
Old Feb 17, 2017 | 03:55 PM
Alex J's Avatar
Thats how I would have installed them. It might come with that hardware for using them on a D1 because I think their kit fits both D1 & D2.
Old Feb 17, 2017 | 06:35 PM
The Deputy's Avatar
Are you sure the spring is on right? Doesn't seem right, looks upside down.
Brian.
Old Feb 17, 2017 | 06:38 PM
Jeff Blake's Avatar
The flat side is on top, so I'm pretty sure I have it right. And the end part of the spring fits into the recess on the inner side of the spring mount. The axle is hanging pretty loose there, so maybe thats why it looks off.
It wasn't easy to get the darn thing lined up. Tore up the rubber isolator a bit. Had to use a pry bar to align it, and then jack up the axle at the same time. The shock does not seem to sit straight up and down, the bottom bushing is angled a tad.
Old Feb 17, 2017 | 06:46 PM
The Deputy's Avatar
Normally, flat side goes down.
Brian.
Old Feb 17, 2017 | 06:48 PM
Jeff Blake's Avatar
Brian.
98% sure flat side goes up...
i also had to use a spring compressor, which I wasn't expecting. Even with the axle fully dropped and resting on the crossmember. These are TF HD springs
Old Feb 17, 2017 | 08:01 PM
The Deputy's Avatar
Yeah, I may have had a brain-fart.
Disregard.
Brian.
Paul Grant
Jul 30, 2016 09:01 AM
acamato
Sep 19, 2014 10:44 AM
peanuts8888
Dec 26, 2012 04:53 PM
sclarkie
Sep 7, 2011 06:04 PM
MONTANACW
Feb 2, 2007 01:22 PM
