Could have seized CDL
Old Jun 28, 2009 | 07:48 PM
JBEGIN's Avatar
Default Could have seized CDL
I can get into low but CDL nipple just wont turn. i was trying to go clock wise.
Old Jun 28, 2009 | 08:17 PM
Did you try counter clockwise?
Old Jun 28, 2009 | 08:32 PM
Put the e-brake on, tranny in netural as well as the t/case, then try it clock wise only, about 45 degrees.
Old Jun 28, 2009 | 08:42 PM
JBEGIN's Avatar
Spike I tried it going both ways, just to see if it would move and it wouldnt at all.
Mike I did have the parking brake on, and was in neutral/neutral... wouldnt go....
thing is it worked a couple months ago, and I changed the gear oil in the transfer case with Royal Purple 75-140 but neglected to lock it up and run it thru the hi and lo positions, forward and reverse like i did the first time i got it engaged.... I fear the worst as i just didnt use the CDL after lubing.
so if i can get into low but cant move the nipple, is it just a solenoid issue in there, or is the transfer case beat?
Old Jun 28, 2009 | 08:54 PM
JBEGIN's Avatar
Ill try again tomorrow with in High and tranny in neutral, when the truck is cold
Old Jun 28, 2009 | 09:33 PM
AK Rover's Avatar
Try spraying it with penetrating oil.
Old Jun 28, 2009 | 09:39 PM
JBEGIN's Avatar
okay, ill try doing that... transfer case has to work if i can get into lo, right?
Old Jun 29, 2009 | 12:04 PM
JBEGIN's Avatar
so to sparay it with a penetrating oil, can I use wd-40? I have a fresh can of PB blaster if that wd-40 doesnt get er done.... just would like to use the wd up first
Old Jun 29, 2009 | 02:12 PM
JBEGIN's Avatar
I got it! the wd-40 took a little bit of sitting and I was finally able to UNseize the pin and engage CDL... I thought it was messed up when i went to unlock it, because the light on the dash of axles didnt want to go out, but i got it to go out after i was sure i was all unlocked and went 30 ft straight ahead and it went out.... AKrover thanks for the idea man i was worried my CDL wasnt workin.
turbodave
Mar 29, 2019 07:22 AM
Noah360
Sep 6, 2009 10:05 PM
fpapai
Oct 29, 2007 12:30 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
