Couple of weird quirks I noticed after 16 years
Old Jan 18, 2021 | 10:57 PM
Tony Luna's Avatar
Default Couple of weird quirks I noticed after 16 years
‘04 D2
I cannot turn on the front dome light. It works fine when the door is open. Just cannot turn it on using the switch with door closed. Swapped it out for the center dome light - which I could turn on using the switch in center position. Didn’t work - and the front dome light in the center position now works fine.
Cannot roll the drivers window up or down if the door is open. Works fine when the door is closed.
Anyone else experiencing this?
thx,
Old Jan 18, 2021 | 11:17 PM
Richard Gallant's Avatar
My front dome light has the same issue
Old Jan 18, 2021 | 11:32 PM
Best4x4's Avatar
Front dome light will act odd if the ground wire is off. I see it usually disconnected or not put back after a headliner is redone.
With the window I'd inspect the wiring in the black rubber grommet between the door/body or the harness behind the driver kick panel.
Old Jan 18, 2021 | 11:36 PM
Tony Luna's Avatar
Well, I did redo the headliner a few months ago.
And did have the drivers door off about a year ago when I fixed the broken check strap mounting point. Disconnected the door harness and pulled the connector through the hole.
Old Jan 19, 2021 | 01:30 AM
nashvegas's Avatar
RE: Front dome light, I had the exact same issue after I redid my sunroofs and water leak chasing with the headliner out. What I found ....
1) On the *rear* sunroof, there is a single pole ground wire, that is attached to the tab on the motor.
2) On the *front* sunroof, there is a similar looking single pole ground wire, so I inadvertently connected it to the sunroof motor. I found that instead of connecting to the sunroof motor tab, it attaches to the dome light.
Fixed my issue. Give a try?
Old Jan 19, 2021 | 06:39 AM
redwhitekat's Avatar
Originally Posted by Tony Luna
‘04 D2
thx,
my dome light has same issue
Old Jan 19, 2021 | 08:24 AM
Tony Luna's Avatar
Thanks! I know exactly what you’re talking about.
Old Jan 31, 2021 | 07:51 PM
Tony Luna's Avatar
That was it. Took the map pocket down, switched ground position form sunroof motor to dome light - BOOM!
Old Jan 31, 2021 | 07:54 PM
Tony Luna's Avatar
On the window - that was it. Squeezed the black rubber wire hose while actuating the window and it worked. Need to look into it. Thanks!
Disco_Dion17
May 1, 2018 05:52 PM
mikebaus
Aug 15, 2015 09:58 PM
LADEROUTE
Jan 9, 2013 08:01 PM
joefresso
Feb 5, 2011 01:48 PM
97vitesse
Jul 1, 2006 10:10 PM
