Cracked Block?
Old Aug 8, 2018 | 12:42 PM
  #111
KernowDiscovery's Avatar
Sorry guys, it was a ball joint on the driver side that is loose.. not a bearing. I had the bearings replaced last year or so.
Old Aug 8, 2018 | 12:43 PM
  #112
Originally Posted by Dave03S
I would suggest you have the front cover looked at before they take off the heads, much cheaper to find that first if it is indeed the problem.
I'll do that.. ask them if they can look at the front cover first.. that would at least rule it out, right??
Old Aug 8, 2018 | 12:47 PM
  #113
Sixpack577's Avatar
Originally Posted by KernowDiscovery
I give the guy kudos and think it's a great idea but... have you checked out his video on youtube? Why is it so noisy? Just the initial stages?
Noise is always hard to tell on a video, for alot of reasons.
The video I saw also had no hood on it.
The stock exhaust will not bolt up directly either, so a muffler shop will have to fabricate some pipe. And I'm not sure what exhaust he has on it at the moment.
But, with a catalytic converter and stock D2 or LS muffler, it will be as quiet as a new GM truck.
Still, given the price of a Turner engine, I'de save some money and go GM.
If money was no option for me, I'de boat anchor my 4.6 today for an LS3.
Old Aug 8, 2018 | 12:51 PM
  #114
Sixpack577's Avatar
Have you considered just buying another D2?
I see lots of overpriced junk, but occasionally, a good truck at a good price pops up.
Again, given the cost of a new engine, plus labor, you may be better off.
Extinct has a great looking black(03?) for sale, with everything it needs done, and then some.
You could buy something like that and still save money...plus you'de have a parts truck.
  #115
Well if I do need a new engine I may just park Bertha and wait on that kit to come out
Old Aug 8, 2018 | 12:52 PM
  #116
Not to drive, no. If I bought another D2 it would be for the parts and I'd keep this one. I'm sentimental.
Old Aug 8, 2018 | 12:55 PM
  #117
Sixpack577's Avatar
Gotcha, maybe find a good running wrecked D2 then, and swap parts.
Old Aug 8, 2018 | 01:00 PM
  #118
CollieRover's Avatar
Sensible decision. If it is the heads, get on the waiting list for the LS3 5.3 swap, or you could get a 4.8 LS3 really cheap, they are the same block I believe, but that may affect wiring harness. I don't know, but they would.
Old Aug 8, 2018 | 01:26 PM
  #119
jastutte's Avatar
did you see a lot of coolant in the oil? The entire vehicle reeks of coolant.
Did you replace the front cover or have it professionally done?
i had a sudden loss of coolant, temps started to run higher and I could smell coolant.
i had a shop do the front cover. i wasn't confident i could tackle that type of work. now after having done the water pump the extra steps to do the front cover don't seem that intimidating.
Old Aug 8, 2018 | 01:43 PM
  #120
That is exactly what happened to me. Sudden loss, temps went higher and then overwhelming smell of coolant. Good to know - thanks!
