Crackle Sound on acceleration from stop.
Old Mar 18, 2009 | 02:49 PM
tiredone's Avatar
Default Crackle Sound on acceleration from stop.
I periodically hear a crackle sound on accelerating from a stop toward the right front of my 99 DII. It doesn't happen once the car is moving and I accelerate. It happens every once in awhile.
Old Mar 18, 2009 | 03:13 PM
okdiscoguy's Avatar
bearings? Swivel ball? Have you re-built your driveshaft yet? The driveshaft would be the crucial place to start. If it fails on the highway, you will punch a hole in the tranny...
Old Mar 18, 2009 | 04:21 PM
tiredone's Avatar
I replaced the front drive shaft with nipples to lube 'em up two years ago.
Old Mar 18, 2009 | 04:28 PM
tiredone's Avatar
It is actually more prevelant when I turn right than left or straight.
Old Mar 18, 2009 | 04:38 PM
okdiscoguy's Avatar
Check the wheel bearings and move on to the CV joint after that..
Old Mar 18, 2009 | 05:43 PM
CV joint going bad.
Only happens when turning and under power...CV joint.
Old Mar 18, 2009 | 06:14 PM
tiredone's Avatar
Boots on the cv joint not torn. Still suspect failing CV joint? If so, do both sides need to be replaced or just one. How would i do an inspection to determine?
sloppyjoe's Avatar
CV joint,,,
Old Mar 18, 2009 | 06:25 PM
The boot does not need to be torn for a CV joint to fail, just plain old age/miles.
Just replace the failed one...unless you have money to burn.
Old Mar 18, 2009 | 07:32 PM
tornado_735's Avatar
I had a 1995 Ford Aerostar AWD with a front CV joint that was failing. Didn't have the money to fix it, so I drove it like that. I drove 30,000 miles on that bad cv joint.
