Crank pulley washer
Old Sep 18, 2012 | 07:10 PM
SolbergFanBoi's Avatar
Default Crank pulley washer
Hey guys,
Been awhile... The Disco is now back on the road after a new transfer case, oil pump and associated parts. Everything is great with the exception of the crank pulley washer just dangling. Could someone tell me which way it faces? Mine could be backwards as the raised edges are facing the engine. Also, what purpose does the washer serve?
Old Sep 19, 2012 | 07:13 AM
drowssap's Avatar
are you talking about the washer that sits behind the bolt that holds the harmonic balancer/crank shaft pully in place?
Old Sep 19, 2012 | 11:27 AM
Alan Phillips's Avatar
I don't recall there being a ridge on the crankshaft bolt spacer (it's a little thick to be just a measly washer). If that spacer is loose then the pulley is also loose.
Are you talking about that sensor on the timing cover? I think a picture would help.
Old Sep 19, 2012 | 12:42 PM
drowssap's Avatar
that's what I was trying to find out; sound like the crank bolt is not tightened all the way. It may be hydrolock, you may want to pull that bolt out and blow air into the whole in the end of the crank and re-install the bolt, you could have coolant in there which will not compress and stop the bolt from thightening all the way.
Old Sep 20, 2012 | 11:05 AM
My bad guys... My description was a total fail. I'm referring to the large dinner plate shaped washer behind the crank pulley (gold in color) that sits between the pulley and the timing cover. It's possible I put it on backwards and is just dangling in there. I was hoping to get clarification what direction it faces. Raised edges facing the pulley? or raised edges facing the timing cover?- how it currently is now. Also, what is the purpose of this part?
Old Sep 21, 2012 | 08:31 AM
There is no washer between the cover and the pulley. You might want to post a picture of what you're dealing with.
Old Sep 21, 2012 | 07:58 PM
lordmorpheus's Avatar
I just checked the junk engine in my garage. The saucer shaped disk behind the balancer has the flat side facing the balancer, and the "lips" pointed toward the engine.
Old Sep 21, 2012 | 11:45 PM
I guess my engine was built on a Friday, I didn't have a saucer shaped washer, that or it was stuck on the pulley and didn't notice it when I did the timing cover gasket.
94svt50
Apr 9, 2012 04:36 PM
greg409
Feb 24, 2010 12:35 AM
krazzz
Jan 15, 2010 07:17 AM
lipadj46
Nov 15, 2009 11:27 AM
shonuff93
Oct 7, 2009 07:24 AM
