Crank sensor problem?
Hi Guys!
Driving to work at around 40 mph and the truck "staggered" felt like it quit for a microsecond and then resumed running. It quit for such a short moment of time I believed it had just slipped out of gear....(02 Disco/auto)..could feel/hear the drivetrain lash and clunk. Went home and then to Auto-Zone and on the way it did it once again.
Took it to Auto-Zone and had the codes read as Follows:
P1884/Transmission transfer case disengaged, solenoid short to ground.
P0335/Crankshaft position sensor "A" circuit fault. Probable cause: faulty sensor, short circuit, poor electrical connection.
Only other indication was a check engine light that went off after a couple miles.
So, I'm thinking a Crank Sensor replacement is needed...agreed? I haven't been driving it since it happened.
Only problem I see is that the electrical plug/clip for the thing is in back of the engine and kinda hard to get to.... I'm thinking I can unbolt the sensor, then hook it with a wire and pull it up from above in order to get the connector within reach... would appreciate some pointers if anyone has a better technique....
