crankcase Question
Old Sep 23, 2008 | 12:34 AM
theworks001's Avatar
Default crankcase Question
I was wondering Is the crankcase the same as the oil pan?? If not tell me where the crank case is.
sorry for the stupid question.
thanks
Old Sep 23, 2008 | 01:01 AM
WolfPack's Avatar
Default RE: crankcase Question
The crankcase is the area beneath the pistons, with the cam. It is where all the 'cranking' of the piston rods happens from the cam up into the cylinders.
The oil pan is just the bottom of the crankcase. Its the bottom catch all for the oil. The oil pickup tube sucks up the oil from the pan, and takes it back up to the top of the engine to circulate again.
So yea they are kinda the same general area of the engine, but they're not the same thing exactly
Old Sep 23, 2008 | 10:18 AM
So when they say drain the crankcase what does that mean??
thanks
Old Sep 23, 2008 | 11:17 AM
When somebody says drain the crankcase they mean drain the oil. The sump is the oil pan, the crankcase is the middle from the middle of the engine and lower.
If you look at the front of the engine you will notice that it is shaped like a "V".The bottom of the "V"starts the crankcase.
It is not specific, and saying the crankcase just means the oil pan for all intensive purposes.
And there is no such thing as a stupid question, if youi dont know then ask.
paulfromperu
Apr 19, 2009 10:14 PM
kean
Feb 24, 2009 03:41 AM
mcrw
Jan 29, 2009 06:20 PM
2000 Disco 2 SD7
Sep 4, 2007 05:01 PM
Doss
Jul 5, 2006 05:10 PM
