crankshaft sensor
Old Sep 3, 2010 | 05:12 PM
rbaaddison's Avatar
7th Gear
Default crankshaft sensor
is there a way to test the crankshaft positing sensor on a discovery 2 with a 4.o liter. i have no signal to the coil pack for spark from the ecm or a signal from the emc to the fuel pump relay can any one give me some advice thank you for your help
Old Sep 3, 2010 | 05:39 PM
No there is no way to test it.
Just replace it, its bad.
Old Sep 4, 2010 | 07:42 AM
Bundu's Avatar
Banned
You test it by turning the key, no start... bad sensor.
Old Sep 4, 2010 | 09:22 AM
Actually if you have a good scanner, you can test the sensor to verify the signal coming from it to see if it has failed.
Old Sep 4, 2010 | 09:29 AM
ROVERTECH15's Avatar
yes definitly the crank sensor not a uncommon problem with these trucks replace it and you should be in good shape
Old Sep 4, 2010 | 12:00 PM
hilltoppersx's Avatar
buy an extra and keep it in the glove compartment in case it happens again and you are far from home.
Old Sep 4, 2010 | 12:06 PM
antichrist's Avatar
You should be able to find it locally cheaper than from the Rover Parts houses.
Standard Motor Products PN PC580. Most any parts store should be able to cross from it if they don't carry SM.
Old Sep 18, 2010 | 01:32 PM
ttownrican's Avatar
8th Gear
we are having problems just changed spark plugs and car will not start help plz.
EVN137
Oct 6, 2024 12:48 PM
vserduchka
Dec 4, 2009 05:57 PM
browndogq
Jul 7, 2009 01:44 AM
pilsner
Mar 26, 2009 04:26 PM
smi8387
Feb 7, 2006 01:15 PM
