Crankshaft Wobble
Old Jan 10, 2017 | 04:16 PM
Oasisplayer311's Avatar
Default Crankshaft Wobble
This is for a 2003 D2
So replaced water pump, oil pump, timing chain and cogs, and crankshaft seal 10k miles ago. Noticed I had some oil leaking from the crankshaft seal and my pulley was wobbling.
So I tried tightening, would not tighten anymore.
Replaced the pulley with a used one that "looked" like it was in better condition, wobbles even more.
So I'm wondering if my crankshaft bearing are bad. I'm really at a loss here. I do have a rough idle as well, and shaking goes away when I rev it up
Old Jan 10, 2017 | 04:33 PM
Jeff Blake's Avatar
One thing to consider is that the pulley, crankshaft, and flywheel are all externally balanced together with the pistons, conn rods, etc. If you replace a component, the engine should really be re-balanced. However, if you notice on the harmonic balancer there is a weight crimped onto it... could be 5g, 10g, or whatever. Make sure to put the weight onto the new pulley in exactly the same position.
Also check the rubber damper on the pulley to make sure it isn't cracked, warped, or damaged.
Old Jan 10, 2017 | 07:12 PM
I didn't know they were all balanced together? How would you go about balancing the engine?
Could it be my crank bearings that are failing?
Old Jan 10, 2017 | 07:47 PM
Jeff Blake's Avatar
Check what I mentioned above first?
A professional would balance the engine. Shouldn't be necessary here though.
Doubtful its the bearings
Old Jan 10, 2017 | 08:05 PM
abran's Avatar
If done correctly, each item is balanced separately that way if one fails/replaced all the items do not need to be re balanced.
Old Jan 10, 2017 | 09:04 PM
Red5's Avatar
If the bearings were worn to the point that the crank could wobble, your oil light would be on pretty much all the time. Engine would sound like hell too.
How much wobble are you seeing? Did you verify that everything was running smooth and true right after the work 10K ago?
Old Jan 10, 2017 | 09:49 PM
abran's Avatar
^ agreed
Old Jan 10, 2017 | 10:24 PM
That's what I was thinking. Would be odd if an entire assembly was balanced together. But if I'm still getting wobble and a rough idle, would you consider bearings?
I have checked everything else. Sensors, air leaks, oil, everything is good except for my idle and my harmonic balancer wobble
Old Jan 10, 2017 | 10:26 PM
It was my first head gasket job, but followed it to the book (manual). So it could have been something I F***** up along the way. Just not sure what it could be
Old Jan 10, 2017 | 10:30 PM
abran's Avatar
Just for sheets and giggles, take off belt and run for e few minutes. Does crank pulley still wobble?
