Crap- EMERGENCY: Won't Start and am late
Old Nov 18, 2009 | 10:38 AM
Disco2Fever's Avatar
Default Crap- EMERGENCY: Won't Start and am late
Hey guys, I am writing to you in dire circumstances.
My 2004 Rover won't start, and I have to be at a funeral, which requires that I leave in the next 20 minutes.
I drove it to breakfast two hours ago, and it was fine. All electronics work- I really think it's NOT the battery, but as soon as I post this, I'll be hooking up the charger nonetheless.
When I turn the key, everything comes on like normal. But when I attempt to start it, nothing happens, except for a loud click from below the engine- which I'm guessing is the solenoid.
Has my starter gone bad?
Is there an emergency trick I can use to start it? My close friend lost her father, and I really want to go. Can I ground the two posts on the solenoid like I could on my old tractor?
Thanks brothers,
Pat
Old Nov 18, 2009 | 10:43 AM
Rover Chris's Avatar
try tapping the starter gently with a hammer, sometimes the bendix gets jammed
Old Nov 18, 2009 | 10:45 AM
Chris, I've got a creeper down and a hammer all ready- I'm trying to locate the starter- can you tell me about where it is under there? I can usually spot them...
THANK YOU SO MUCH!
Old Nov 18, 2009 | 10:47 AM
Found it- am tapping- nothing yet.
Old Nov 18, 2009 | 10:54 AM
you could try shorting the terminals on the starter to see if it will kick over as this will bypass everything else, just another thought
Old Nov 18, 2009 | 11:04 AM
alanroberts50's Avatar
While you are there check the security of the terminal wiring connections too.
Old Nov 18, 2009 | 11:09 AM
Battery terminals look shiney, and the wires are tight- would the soleniod still click if it wasn't getting power? THANK SO MUCH for the help guys! Not sure if I'll make it in time, but I guess I gotta fix it eventually.
Old Nov 18, 2009 | 11:14 AM
NiteTrain's Avatar
I know you're in a hurry but you need to verify it's not the battery first...maybe borrow a battery from a neighbor's car if you dont have a spare one
also, some battery chargers have a 50amp 'start mode' to jump your vehicle
Old Nov 18, 2009 | 11:21 AM
Nite Train, I love your avatar and signature.
Thank God, I have a friend going to the same funeral who is about to stop and pick me up- I'll try to jump it from my wife's Rover when she gets home tonight.
Thanks so much, guys!
Pat
Old Nov 18, 2009 | 11:26 AM
NiteTrain's Avatar
thanks, glad to hear you got a ride. If your battery is really dead a jump might not work..you might have to put her battery in your rover to verify that is the problem.
