Crazy A/C Climate Control
My climate control is not working properly. Driver side does not blow hot air (as hot as the right side) and the right side does not blow cold air (as cold as the driver side). This is happening when both side are at the same temperature in the A/C climate control.
What's going on?
What's going on?
Could be either the duct sensors failed or the A/C computer control unit taken a powder. They are generally pretty robust apart from the lamps in them. My 'guess' is it's the duct sensor(s) playing up. If you can get your hands on a good code scanner (Hawkeye or Nanocom or similar) it should throw up a code showing what has failed in the A/C system.
Green Blood
Dec 22, 2018 04:40 PM
joshualaterra
Sep 30, 2011 08:38 PM
dbs600
Jul 11, 2005 08:44 PM
