Crazy OBDII codes Disco I
Old Jul 13, 2009 | 10:31 AM
They can't flood, be more specific.
Old Jul 13, 2009 | 02:20 PM
NM-DiscoDuck's Avatar
Ok... It acted like it was flooded. After I checked all the plugs for fouling (all were normal), my wife went out for a few errands. After one stop, she called to tell me that it was sputtering badly on start-up. About 2 hours after she came home, we wanted to go out to eat, but it just wouldn't turn over. The engine would crank, and sputter, but not start. This morning, everything was back to normal.
How's that?
Old Jul 13, 2009 | 02:52 PM
lipadj46's Avatar
So did you get 8mm magnecor wires yet? If not try that. Here is the best price:
http://www.apexperformance.net/cartg...t.asp?scat=306
Old Jul 13, 2009 | 05:21 PM
Funny... I was just looking at another thread about the SRS light flashing, and looked up Apex Performance.
In all of my years of working on vehicles, the only time I've ever had to upgrade plug wires was if I had a really hot coil upgrade. You think that's the trick, huh? That's going to solve the "running rich" codes and the occasional cylinder #1 misfire?
Old Jul 13, 2009 | 05:28 PM
lipadj46's Avatar
The engine is aluminum and runs hot and eats regular non silicone wires fast. The magnecors do the trick most of the time like magic. Most people here are believers and I personally have a set in my truck and solved my misfire issues. I can't hurt either way and you will need them eventually.
Old Jul 13, 2009 | 08:10 PM
Well.... I'll give it a shot. Can't hurt, right?
Old Jul 13, 2009 | 08:46 PM
lipadj46's Avatar
Well you can test your wires by spraying water on the ends over the spark plugs and shaking them (with a pair of rubber pliers or wearing rubber gloves) in the dark. If you see arcing they are toast.
Like you said it can't hurt and you will need to do it sooner or later. Normal autozone type wires can be eaten up in a month by a Disco.
Old Jul 13, 2009 | 08:59 PM
The wires may need to be changed, but will not cause the sputtering and hard start.
You may have a crank sensor starting to fail.
If you have the original factory gray wires, do yourself a favor and order a set of 8mm Magenacor.
jycsalas
Mar 13, 2009 01:11 PM
mge_1
Jul 12, 2008 08:45 AM
Camdisco24
May 28, 2007 09:23 PM
JRdisco1
Aug 5, 2005 12:25 AM
izzy
Feb 27, 2005 10:43 PM
