Crazy starting situation
Old Mar 20, 2012 | 03:41 PM
Psichotic's Avatar
Default Crazy starting situation
Ok heres the deal.
2001 Discovery II, it has been acting like the battery is dying when I use the key lock/unlock and struggles to unlock the doors. Once inside if I just try to start the truck normally the alarm will go off and I can turn it off with the fob.
OR
Unlock the car with the fob, turn the headlights on and it starts up like a champ....however. If I come to a stop and go when I shift from 1st to second gear the radio/cd will power off and my headlights flicker. Then come back on.
This morning the truck unlocks from the fob at full power, zero problems, Insert the key and it tries to start, starter going strong but no ignition. If anybody has a clue what this is all about you are my hero. I can post a video of it trying to start or pictures of anything that my help a solution, thanks for reading!
Old Mar 20, 2012 | 05:05 PM
So, go clean and tighten all your grounds and battery cables then go to a local parts store for a free charging system test. You will need voltage from 13.6 to 14.4 volts, let us know what you find.
Old Sep 20, 2016 | 10:58 PM
Mr. Moore's Avatar
Originally Posted by Psichotic
Ok heres the deal.
OR
Typically it only takes 8volts to crank an engine over, however most of the computers and electronics that operate/actuate things need at least 12 volts. If your battery isn't taking a good charge from the alternator or the alternator isn't supplying enough power to be able to power the vehicle while it is running and charge the battery then you will be constantly loosing power to run things and the vehicle will cut power to things to keep itself running. Definitely get the battery and alternator tested. Just make sure you get it tested by somebody that actually knows how to do the proper tests so you don't buy parts you don't need.
Old Sep 20, 2016 | 11:10 PM
KernowDiscovery's Avatar
this thread is over 4 years old..
Old Sep 20, 2016 | 11:20 PM
Mr. Moore's Avatar
just noticed that, thanks!
tweakrover
Sep 4, 2012 12:23 PM
tweakrover
Feb 17, 2010 12:11 PM
flattrakker
Jan 15, 2008 06:11 PM
RovingRiesensCubed
Jan 12, 2008 01:11 PM
DiscoDiva
Jan 29, 2007 08:00 PM
