CRC engine cleaner, good/bad?
Old Mar 12, 2016 | 07:21 AM
BS50MGSXR's Avatar
Default CRC engine cleaner, good/bad?
My neighbor loves the stuff. He have me a bottle to put in the D2. Anyone ells run this stuff with good results?
He says he dumps the bottle in with the oil, drives 30 to 60 miles then dumps it and does a oil and filter change.
Helps remove sludge and carbon build up or so it says on the can.
Old Mar 12, 2016 | 08:25 AM
Colorado David's Avatar
I'm not familiar with this specific product, but I'd be reluctant to use any additive product not made by BG Products. I have high confidence that the stuff they make is high quality and has been tested to do what they say it is supposed to. I use the BG MOA oil treatment and the BG 44K fuel system cleaner. Their products are not cheap, but they do what they claim they'll do.
Old Mar 12, 2016 | 09:33 AM
Best4x4's Avatar
I've used Seafoam to do the same thing.
Old Mar 12, 2016 | 09:23 PM
BS50MGSXR's Avatar
ah, just looked at the bottle, called CRC Motor Treatment.
how did the sea foam do? u do half the bottle in a full tank of gas and the other half in the engine oil?
Old Mar 12, 2016 | 10:57 PM
number9's Avatar
They recommend that amount if 16oz can in the oil and run 100-300 miles. That's what I did and Rover still purrs.
Sea Foam Sales Company - How to add Sea Foam Motor Treatment to Gas and Diesel Crankcase Oil
Old Mar 13, 2016 | 09:59 AM
Best4x4's Avatar
Yep I used it as mentioned above on a 97 RR I had. Worked great!
Old Mar 13, 2016 | 10:33 AM
Charlie_V's Avatar
Every time I have done the full seafoam treatment (gas tank and into the manifold) some other problem crops up like 02 sensors or a vacuum leak. Could be coincidence. Or it could be that my engine wants to be a little dirty.
Colorado David
Sep 2, 2014 07:42 AM
TRIARII
Dec 14, 2012 09:52 AM
herblatham
Mar 15, 2009 07:25 PM
targotsi
Jan 31, 2009 06:12 PM
DeepBlueWater
Oct 15, 2007 07:38 PM
