Cruise Control on a 2000
Old Feb 13, 2009 | 02:47 PM
russoaks's Avatar
4wd High
Default Cruise Control on a 2000
Is this the cruise control module? If so - does anyone have link with a diagram that shows me where/how to route the "missing" tube(s)?
File Type: mov
Old Feb 13, 2009 | 02:52 PM
okdiscoguy's Avatar
There should be a vacuum hose coming off it, going into a tee fitting. One goes to your brake pedal and the other to a vacuum pump. I know on a D1 it is under the jack on the drivers front, but I think on a D2 it is passenger side closer to the firewall
Old Feb 13, 2009 | 03:03 PM
russoaks's Avatar
4wd High
No t fitting - no hose either - other than the 1/2 inch broken off piece still attached to the device in pic 1.
Old Feb 13, 2009 | 03:14 PM
okdiscoguy's Avatar
There should be a switch on your brake pedal. Feel up the arm of the pedal. one is electronic, and the other is for the hose. Follow it out through the firewall and see what it is connected to..
Evan5291
Nov 21, 2017 07:59 AM
filmhog
Jul 14, 2012 05:32 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
cosmiccharlie79
Jun 16, 2008 09:13 AM
2000 Disco 2 SD7
Jul 24, 2007 02:28 PM
