Cruise Control
Old May 24, 2012 | 11:51 AM
30more's Avatar
Default Cruise Control
Cruise Control pump thing want out again, I bought this rover with a bad pump in it. Fixed it by putting a used one in. Was using my cruise control on a long trip and I started to lose speed now not working at all.
Any suggestions would be great!
Thanks, Joe
Old May 24, 2012 | 12:02 PM
thebloody's Avatar
I take it you have checked all the fuses to make sure that none have gone bad?
Old May 24, 2012 | 12:19 PM
drowssap's Avatar
you may also want to check for old cracked vacuum lines going to and from the pump.
Old May 24, 2012 | 09:36 PM
br0keit's Avatar
Losing speed then not working at all is most likely a cracked hose. Yank the hose off and check for cracks. If it is about $2 at a parts store should get you some replacement vacuum hose to replace with and you'll be all set.
Old May 26, 2012 | 05:22 PM
30more's Avatar
its a cracked hose!
thanks,
Joe
Evan5291
Nov 21, 2017 07:59 AM
37chambers
Oct 18, 2016 10:52 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
anonimaus
May 9, 2005 10:01 PM
flowers
Apr 12, 2005 04:03 PM
