Cruise Control
Old Oct 23, 2012 | 02:11 PM
lilherc's Avatar
Default Cruise Control
Hey guys if have the 3 Amigos on will that cause my Cruise Control to stop working. They seem to have hapened around the same time. No Fault Codes present
Old Oct 23, 2012 | 02:54 PM
Bamberson's Avatar
Not sure if it effects the CC, but I would check the vacuum lines on your CC to see if any are cracked. My '00 had a small hole that made it not work.
Old Oct 23, 2012 | 03:24 PM
Antmen's Avatar
Is your horn working? When my horn fuse (under hood) was blown, my cruise control wouldn't work.
-Anthony
Old Oct 23, 2012 | 04:10 PM
lr2001silver's Avatar
Banned
Definitely check hoses for vacuum leak and high possibility, the cruise control module is located behind the kick panel on passenger side. It could also be bad but do look very close for a vacuum leak first.
Old Oct 23, 2012 | 05:51 PM
lilherc's Avatar
Will check all that was suggested and get back u yo guys thx.
Old Oct 23, 2012 | 09:57 PM
Bkreutz's Avatar
3 Amigos won't affect the CC. Try turning your radio off and then try to set the CC (that's how I figured out the rotary cassette was bad in mine) D2's aren't as prone to vacuum leaks as D1's were. The only vacuum lines are all near the pump and actuator (instead of running all over the engine compartment and to the brake switch on the pedal)
Evan5291
Nov 21, 2017 07:59 AM
37chambers
Oct 18, 2016 10:52 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
anonimaus
May 9, 2005 10:01 PM
flowers
Apr 12, 2005 04:03 PM
