Cruise Control Fix
Old May 31, 2013 | 07:12 AM
haz432's Avatar
Default Speed Sensor Incorrect Voltage
TMadsen, I have the same fault exaxtly...
Did anyone find a solution?
Originally Posted by TMadsen
Please help me up you can . My cruise does not work at all . I have replaced all hoses and gone through all checks . All diagnostic checks are good except the wheel sensor voltage . When checking to the voltage I get a constant 8.75 volts . Sometimes when all wheels are not turning I get 12 volts sometimes when wheels are not turning I get 0 volts . When I turn a rear wheel by hand the voltage will vary between about 5 and 12 volts . When I turn the wheel with the engine I get a pretty steady 8.75 volt no matter how fast or slow the wheel is turning . I get the exact same results when turning either rear wheel . I true testing with front wheels and get 0 volts at all times . Is this normal ? I have tried 2 different ecu's . Antilock brakes seem to work fine . No fault lights are on . Speedometer works ok , it does fluctuate a little now and then and it does read about 3mph slower then actual speed .
Old Sep 5, 2013 | 01:50 PM
chavalkoko's Avatar
I have issues with the cc and have gone through guide,excellent by the way,came up with the conclusion the ecu is bad.Any suggestions on where to get a low priced unit?
Old Sep 5, 2013 | 02:50 PM
Paul Grant's Avatar
I have plenty of DII ECU's for $17.49 shipped with a 60 day replacement warranty. If you want one you can either use PayPal (paulgrant@mac.com) or you can call with a credit card (203-770-1699).
Cheers,
Paul
Old Sep 6, 2013 | 10:40 AM
chavalkoko's Avatar
Thank you for responding.I had a response earlier and bought one.
Old Sep 26, 2015 | 03:09 PM
TomOwen's Avatar
Hi, I have this same issue, 7-8v on rear wheel. Did all the other checks and held vacuum etc fine. Is there a resolution to this issues? Speed sensor faulty? I have an R380 in my '96 D1. Thanks!!
Old Jun 12, 2016 | 01:49 PM
jepajo's Avatar
5th Gear
Default '99 Disco 1 Cruise problems
My voltage jumps from 12 volts to 0 averaging about 8 volts. Referring to test #7 about the VSS. your test says should be 0 to 5 volts. This is the only test that does not check out. Is that voltage saying my VSS is bad?
Evan5291
Nov 21, 2017 07:59 AM
houmem24
Aug 23, 2016 11:59 AM
lsmit605
May 11, 2011 11:50 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
JoeyDisco96
Oct 8, 2008 03:33 PM
