Cruise control master switch
Old Aug 14, 2016 | 05:58 AM
Wayne Mccants's Avatar
Default Cruise control master switch
Master switch when depressed blows the 20 amp fuse . I've tried everything . Checked all hoses changed the cruise control module brand new.checked all my hoses clips in engine.
Old Aug 14, 2016 | 07:11 AM
disc oh no's Avatar
You have a dead short to ground somewhere. I would start from the engine compartment and inspect the wiring from the cruise control assembly back. It's much more likely to have a problem near the engine because of all the heat and movement.
Also, does the fuse blow as soon as you put it in, or just when you switch the cruise control on? Determining that will tell you if it's in the supply, or switched side of the circuit.
Old Aug 14, 2016 | 03:36 PM
number9's Avatar
Looking at attached diagram would think likely problem between switch and CC ECU. Possibly bad switch. May be able to swap with similar switch. Has it worked since owning? Please provide more info next time.
File Type: pdf
AZRover
Jul 2, 2012 06:43 PM
xhevi
Aug 6, 2010 04:08 PM
AJKILLGORE
May 27, 2010 07:42 PM
98_Disco
Feb 26, 2008 09:03 AM
mdvickst
Mar 11, 2007 12:25 AM
