cruise control problem!
Old Dec 2, 2008 | 09:42 AM
kfx4001442's Avatar
Default cruise control problem!
I have a 2000 Discovery II and have noticed recently that the Cruise Control dosn't work anymore. The button on the dash seems to function properly and I even hear a faint click when pressing the brake while the key is on( I know this has to do with the CC system from reading other posts). It just dsn't engage when I press the SET button on the steering wheel. Any Ideas?
Old Dec 2, 2008 | 01:53 PM
lifewithoutanet's Avatar
Default RE: cruise control problem!
Have you checked the vacuum hose leading from the pneumatic diaphragm in the back-left (when facing the front of the vehicle) corner of the engine compartment?
-C.
Old Dec 2, 2008 | 04:43 PM
snowdude's Avatar
its proably a vaccum line, but.. YOU REALLY WANT TO USE THE LAND ROVER CRUISE CONTROL?!?!? IT SUCKS!!
Old Dec 2, 2008 | 05:01 PM
JimScream's Avatar
When mine went, it was the vacuum hose at the actuator as stated above. The rubber hose after years had cracked. It's an easy and cheap replacement if indeed that's what's wrong with it.
What's wrong with the LR cruise control. I haven't used it extensively but when I have it's worked just fine; my gas foot will attest to that on those occasional long drives...
Old Dec 2, 2008 | 06:42 PM
Buy a can of Liquid Tape and goop up all of your cruise control vacum line connections.
Old Dec 3, 2008 | 12:47 AM
AK Rover's Avatar
I've made 2 long road trips in my Rover so far and I would kill to have my cruise control working. For some reason I can't find a position that is comfortable for holding the accelerator down for any length of time without my leg cramping. I am supposed to take my Rover to Phoenix in February so I am praying I can get my cruise control fixed by then.
Old Dec 4, 2008 | 12:46 PM
Scanner's Avatar
If it still doesn't work after you fix the vacuum lines check to see if your horn works.
The CC is on the same fuse as the horn. Its located in the engine compartment fuse box.
Took me forever to figure that out.
Old Dec 4, 2008 | 01:33 PM
pilsner's Avatar
will someone PLEASE post pics of what i am looking for under the dash/ on the brake pedal and these vacuum lines?!
thanks
Old Dec 4, 2008 | 06:42 PM
http://www.roverparts.com/Parts/XKB000010.cfm
Here is the brake light switch.
Old Dec 4, 2008 | 08:45 PM
pilsner's Avatar
hey snowdude, what is wrong with the rover's cruise control?
