Custom Rear Bumper Construction
Old Jul 8, 2012 | 12:55 AM
FlyingZebra34's Avatar
Default Custom Rear Bumper Construction
So I started building this beast a few days ago, I trimmed the side panels that were already badly dented from bottoming out on them and my plastic bumper finally ripped off from those 2 bolts after getting hung up on a rock.
So the idea was a low profile bumper to match the front, that protected the body and acted as a skid plate to slide off obsticals rather than just get stuck.
Right now the side trim is done and now I need to finish adding the bottom plate and cutting out holes for the lights and a few other details. I used the 2 existing cage nuts and added two more on the same brackets for some extra strength. I will also be adding mounting hard ware that bolts on where the stock hitch bolts to the frame with those 1/2" bolts. Other mounting locations will be added but I'm trying to make it an easy bolt on/off build.
Anyhow, here are the pics! (sorry for the glare)
Old Jul 8, 2012 | 08:25 AM
Looks kind of familiar, here is the one I made 9 or 10 years ago.
Might want to e-mail me and I'll send you some other pictures, especial on the underside, might give you some ideas.
Attached Thumbnails Custom Rear Bumper Construction-dscf0059.jpg   Custom Rear Bumper Construction-dscf0058_1.jpg
goatman
Mar 30, 2020 08:54 PM
bcolins
Jun 22, 2013 08:55 PM
bosshogt
Jul 28, 2012 06:58 PM
jdracersc
Apr 19, 2011 05:18 AM
jdracersc
Feb 2, 2011 05:27 AM
