Custom subwoofer box and amp rack build in my D2
Old Apr 9, 2023 | 03:53 PM
The_OGCJR's Avatar
Default Custom subwoofer box, amp rack, and front stage build in my D2
This may belong in audio/visual but this is D2 specific so I figured I’d post it here. The 1st and 2nd pic is the mostly finished product and the following pics are from the build process.
Old Apr 9, 2023 | 04:03 PM
The_OGCJR's Avatar
So first I started on the subs. This build is all about sq and a little about spl. So I chose Stereo Integrity for the 2 12’s.
Stereo Integrity SQL 12.
The mounting location
What i used to seal the air vent
A layer of fiberglass and stone start of the box
About 5 final layers here
How I got around the seatbelt
Back side near door added
Glass and resin the inside for water resistance and strength
Old Apr 9, 2023 | 04:15 PM
The_OGCJR's Avatar
More build pics
Figuring out total airspace
Checking size for airspace math
Front
Back
Front
In truck without face
I only had one sub at first. So I used the gasket for a template
Here you can see the face didn’t sit flush with the fiberglass because I miss measured BUT fiberglass is forgiving and allows me to patch it
Double baffled the front face (2 3/4in mdf on glued)
In the truck with seat down
With seat up
Old Apr 9, 2023 | 04:18 PM
The_OGCJR's Avatar
More build pics
I wanted to keep all the tie downs so I made sure to build the box “around” it
Old Apr 9, 2023 | 04:21 PM
The_OGCJR's Avatar
I quickly determined I needed 2 subs and so…
the amp rack pics will be posted shortly
Old Apr 9, 2023 | 04:37 PM
The_OGCJR's Avatar
And the amp rack
Old Apr 10, 2023 | 07:33 AM
XRAD's Avatar
Nice work on the enclosures! Do you have a bumper mounted tire rack? Can you post pics if you do...thx
Old Apr 10, 2023 | 08:07 AM
The_OGCJR's Avatar
I do. And yes I’ll post it
Old Apr 10, 2023 | 08:43 AM
jastutte's Avatar
agreed! nice work. you'll turn heads as you cruise around blasting showtunes and Disney musical numbers.
seriously, though. that is some nice work on the enclosures.
Old Apr 10, 2023 | 11:23 AM
greisinb's Avatar
Great work, and I don't even have any interest in car audio! I noticed that you have a load space rack suspended from above, I fabbed one of those up too (my first ever welding project), it really helps storage in the back now that you can take advantage of the D2 height.
