Cv axle leaking- guidance needed
Old Jun 10, 2018 | 07:30 PM
TaylorCadence's Avatar
Default Cv axle leaking- guidance needed
was under the truck for an unrelated issue but noticed my passenger CV is leaking greenish fluid:
Would this be the seal? I’ll have to jack the truck up to test for hubs but could use a little guidance on replacement. I have a parts truck, can I pull from there or get new parts? And how much longer can a drive before it becomes a serious problem? Looking to head out to the beach this afternoon. Any help appreciated
Old Jun 10, 2018 | 07:32 PM
The Deputy's Avatar
That is grease leaking out of a torn CV joint boot. You can replace just the boot, by removing hub and pulling shaft. Relube, install new boot and reassemble.
Brian.
Old Jun 10, 2018 | 07:37 PM
Brian.
man you’re helping me left and right! so nothing serious? Guess I could just take the good boot off my parts rover then... great news.
Old Jun 10, 2018 | 07:39 PM
The Deputy's Avatar
If you have a parts rover, just pull complete axle and slide new one in. Then you don't have to mess with re-booting. It's a messy job...lol.
Old Jun 10, 2018 | 08:15 PM
thats what I’ll do then 👍🏼 thanks again. Got to add it to my already long list of projects
Old Jun 10, 2018 | 08:43 PM
Saturnine's Avatar
Either way, you should probably do it sooner than later. Once the grease is gone, you'll start to hear clicking when turning hard and eventually it'll break.
Old Jun 12, 2018 | 12:07 AM
sounds good. I’m already doing my drivers side ball joints. I’m going to buy passenger side as well since I’ve got to take everything off to swap the axle. If I decided to pack with new grease is there specific grease I should be buying and do I just generously slop it on the the joint and cover with boot? Or do you not advise that and just slide it in like Deputy said. Thanks in advance, really helping me out 🙏🏼
Old Jul 8, 2018 | 05:10 PM
Swapped the axle, all is well 🤙🏼
Old Dec 24, 2019 | 12:55 PM
Carlos Santiago Montoya's Avatar
Default Help cv join right side
Brian.
I have the same problem I want to replace the whole axle but don’t know how to pull it out help please thank you for your time
DakotaTravler
Aug 26, 2018 01:42 PM
Romo12b
Aug 14, 2018 05:08 PM
Kelbird
May 29, 2017 08:11 PM
GROVERtheROVER
Aug 29, 2011 09:37 PM
Luky
Jul 17, 2009 08:32 AM
