Cyl 4 & 7 misfire
Old 09-18-2014 | 07:09 AM
Jared9220's Avatar
Progress indeed. That ECU is more than likely your issue. You should feel proud of yourself for not giving up like the previous owner did.
$10 for a transistor is really steep. You can buy a used ECU with a warranty for around $50-$100 on Ebay. There is also a member on here named Paul Grant and he parts out rovers. If you can't find a good deal on Ebay look him up and send him a message, he will have what you need.
I really admire your willingness to try and fix the ECU, lord knows I wouldn't do open heart surgery on my ECU. I personally would just replace the whole thing and be done with it. Keep us posted on the progress.
  #22
Old 09-19-2014 | 05:29 AM
krammark's Avatar
Would I need the dealer to reprogram the ECU if I swap it out with a different one?
I thought I read somewhere that there was a security code that needs to be reprogrammed so the truck stays running?
Thanks for the tip on the parts guy.
  #23
Old 09-19-2014 | 06:08 AM
drowssap's Avatar
you are correct the ECU's would have to be sync
  #24
Old 09-20-2014 | 04:23 PM
krammark's Avatar
Do you know if the Hawkeye OBDII tool can resync a used replacement ECU?
Is the dealer the only way to get a used ECU sync'd?
  #25
Old 09-20-2014 | 04:52 PM
Jared9220's Avatar
I'm not sure on that. Here is the Hawkeye manual. It might give you a better idea. If all else fails just give the guys at D.A.P a call and ask- Toll Free 800-955-2818
http://www.dap-inc.com/hawkeye/Hawkeye_V5_manual.pdf
I think that programming the computer would be in the "security" section under programming options.
I saw an option in the security section for "Bath Robe Lock" on page 71 of the manual. I wonder what the hell that's for?
  #26
Old 09-21-2014 | 11:24 PM
krammark's Avatar
I swapped out my burnt transistor in the ECU this morning and all codes are clear. No more misfires. I took it for a short ride this evening and still no codes. I'm happy I didn't need to go to the dealer to have a second hand ECU reprogrammed.
The truck runs really nice with all 8 cylinders! Now I need to think about looking at the front drive shaft with all that power but first I need to put my headliner back up since I also fixed two sunroofs. Thanks the help.
  #27
Old 09-22-2014 | 07:51 AM
Jared9220's Avatar
Great Job. You succeeded in repairing what the PO gave up on and sold the truck over. You should take the truck by his house for a victory lap.
wolfgang528
Defender
12-28-2010 04:25 PM
dammad
11-10-2010 04:55 PM
tbesselman
11-17-2006 01:20 AM
cottonpatchweims
08-15-2005 11:19 PM
tbesselman
06-01-2005 01:54 PM
Quick Reply: Cyl 4 & 7 misfire
