Disco II '99 with Misfire on Cyl 6 and 7
Old Apr 14, 2005 | 05:05 PM
tbesselman's Avatar
Default Disco II '99 with Misfire on Cyl 6 and 7
I have a '99 Disco II which had the plug wire changed about 1.5 yrs ago and the plugs changed 5 months ago. Just recently the engine began running rough at 1k-2k RPM and seem to smooth out at higher RPM and acceleration. Then the CEL Light came on. Used and OBD II scanner and pulled these 3 codes. P0306, P0307, and P1300 (misfire 6, 7 and Manf. Control ignition system or misfire). Pulled the plugs on 6 and 7 and replaced them because the were super carboned upped (if that's a real sentence). Should I be looking for something else that caused it or just righ it off as the 2 plugs going bad in 5 mos?
Old Apr 15, 2005 | 01:26 AM
Bait's Avatar
Default RE: Disco II '99 with Misfire on Cyl 6 and 7
Most likely, your exhaust valves are sticking and causing the light.
Old Jun 1, 2005 | 01:26 PM
msupsic's Avatar
Had this problem a few years ago on my 99 disco II... Cylinder 5 misfire. Car would shake violently when I accelerated, and then the CEL would came on. Rover pulled the code, and found it was bad ignition wires fouling out and arcing to the engine block. Rover dealer wanted $600 to replace the wires (what?) so I found a parts dealer in Kentucky, bought the wires for $49 and did the work myself. Since then, no problems.
Also had a problem with Mass Air Flow sensor (once) but nothing since then. Sounds like your problem is ignition or exhast related. Hope this helps.
Old Jun 1, 2005 | 01:42 PM
tbesselman's Avatar
Were the codes for misfire or were they specific to the ignition cables....Thanks!
Old Jun 1, 2005 | 01:54 PM
msupsic's Avatar
Code was for the cylinder - cylinder 5 misfire, specifically. But thanks to that code, we traced the problem to the wires. You could actually see the sparks jumping from the wire to the engine block.
coors
Sep 9, 2011 02:15 PM
dammad
Nov 10, 2010 04:55 PM
southernstemp
Nov 16, 2009 09:39 PM
tbesselman
Nov 17, 2006 01:20 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
