Cyl 7 Misfire I found the issue! Now what
Hi all. I've tried searching this forum prior to asking this question and hope there's a simple answer. Had P0305 and P0307 errors and by reading the forum, I replaced plugs (B +4) and wires (magnecor 8mm). In the process of changing plugs, I found oil coming from the valve cover right above cylinder 7. That original plug was fouled and the others looked better. I've tightened the valve cover which has stopped the leak.
Now, how do I get that pool of oil out from under that plug?
I know that I'm assuming the oil is from the valve cover leak, so let say for this moment that's what it is.
FYI... After replacing the wires and plugs, P0305 was gone and P0307 is not as often. At highway speeds, it's nonexistent. Only at acceleration and deceleration.
Any ideas and am I on the right track?
My D2 with Magnecore 8mm wires and Bosch +4 plugs loves water so much, it produces catalyst-damaging misfires if I even spit on the engine. Be careful. I would recommend taking water to your engine only if you are in your driveway so that you can let it dry out before having to drive it. Been my experience anyway.
-aaron
182,000 miles
2003 SE7
-aaron
182,000 miles
2003 SE7
