Cylinder 1 and 6 misfiring.. Help
Old Oct 13, 2014 | 08:12 PM
cobbcj7's Avatar
Question Cylinder 1 and 6 misfiring.. Help
This truck is running rough (skipping) and the codes are indicating a misfire in Cylinders 1 and 6.. So we put a timing light to the wires to check if its fouled plugs, but the misfire is in the wires.. The code I have is P3401 deactivation of cylinder 1..
What to do?? is this common??
The truck idles ok, but once i'm on the gas, its gutless and runs rough... then the check engine light will start flashing!
Old Oct 14, 2014 | 07:42 AM
Fuddy's Avatar
I had the same issues and a new MAF fixed it.
Old Oct 14, 2014 | 08:59 AM
cobbcj7's Avatar
Is there away to test that before I go buying a new one?
Old Oct 14, 2014 | 10:14 AM
cobbcj7's Avatar
With the engine running, I pulled the plug to the MAF and the first time it stayed running but much rougher, then the second time I pulled the plug the engine died immediately..
From what I have gathered, this indicates that the MAF is working..
Thoughts??
Old Oct 14, 2014 | 11:00 AM
drowssap's Avatar
have you replaced the ignition wires?
Old Oct 14, 2014 | 11:56 AM
cobbcj7's Avatar
Replaced what wires?? I did plug the MAF sensor back up..
The one time I unplugged it, it did chug but stayed running. The second time it died instantly so im assuming the MAF is ok..
I will run an electric reader test on it to see what volts I get
Old Oct 14, 2014 | 12:01 PM
Dave03S's Avatar
He's talking about the wires where the misfires are as you mentioned in your first post.
Old Oct 14, 2014 | 02:46 PM
cobbcj7's Avatar
Question
Oh the spark plug wires?? I haven't because they are not old and the truck was running fine.. Then this situation happened.. So I doubt spark plug wires considering 2 cylinders started misfiring at the same time.
But process of elimination might lead to something..
How does one change spark plug wires when the distributor is buried behind the engine??
Old Oct 15, 2014 | 08:45 AM
drowssap's Avatar
one climbs on top on the engine
Old Oct 15, 2014 | 10:07 AM
agthird's Avatar
plugs and wires start simple....
