Cylinder 1 and 6 misfiring.. Help
you have a misfire on #1  so your going to replace the o2 sensors?
</title> <meta name="robots" content="index,follow" /> <meta name="GOOGLEBOT" content="INDEX, FOLLOW" /> <link rel="canonical" href="http://www.kingsbornewires.com" /> <script type="text/javascript" src="//ajax.googleapis.com/ajax/libs/jquery/1.4.2/j
1 and 6 are on the same coil (drivers side top back center of engine). Feel and look behind there and see if the top two wires on that coil feel like they are on good. Push in hard on them toward the coil and see if they will go in any tighter. It's tight but you can get your fingers in there enough to feel if the wires are tight on the coils. Don't accidentally pull them off, you may never get them back on.
also check the connector from the main harness that plugs into that side of the coil (drivers side). shake it a little to see that it's plugged in good and that the metal clip is still on it.
and open the hood in pitch black dark with the engine running and look for fireworks anywhere.. to see if the wires may be sending the spark somewhere else before it makes it to the plug.
also check plug wires on 1 and 6 at the plugs and see if snapped on tight.
these are just some things you can check that are easy.
I added a wiring diagram so you will know where 1 and 6 are on the plugs and coils.
It was the Coil Pack
[QUOTE=RicketyTick;486243]1 and 6 are on the same coil (drivers side top back center of engine). Feel and look behind there and see if the top two wires on that coil feel like they are on good. Push in hard on them toward the coil and see if they will go in any tighter. It's tight but you can get your fingers in there enough to feel if the wires are tight on the coils. Don't accidentally pull them off, you may never get them back on.]
I replaced the #1 and #6 coil pack and its running fine and not throwing codes.. Thanks Rickey!!
