New Magnecores and Plugs and still misfiring
Old Dec 14, 2008 | 05:05 PM
grussell's Avatar
Default New Magnecores and Plugs and still misfiring
I have double checked the Magnecores and all are routed correctly. The service engine light went out when I installed the Bosch plugs, but after she sat for a week the light and misfires are back. Cylinders 3,4 and 7 which were present before changing the plugs, but only cylinder 3 before wires. The wires seem to be seated in the coil pack so I am stumped.
01 DII 106k
Old Dec 14, 2008 | 06:53 PM
Default RE: New Magnecores and Plugs and still misfiring
That is a tough one, if I remember right you also replaced your coils, are they seated correctly?
I am just thinking out loud here...
Old Dec 14, 2008 | 07:48 PM
grussell's Avatar
No, I did not replace the coils. I will recheck the wires into the coils tomorrow. It is tight behind the coils with the Magnecores. She seems to run decent with no load on the engine, but push the accelerator hard and the misfires are very noticeable.
Old Dec 14, 2008 | 08:01 PM
If all the wires are tight then look for a defective plug.
Old Dec 14, 2008 | 11:22 PM
jojoknox's Avatar
7th Gear
I know a guy with identical scenario; turns out those Bosch plugs have a high infant mortality rate. That guy was sure it had to be something more elaborate than a defective $8 plug!
Old Dec 15, 2008 | 07:00 AM
roverboy's Avatar
champion plugs only
Old Dec 15, 2008 | 10:03 AM
First try and switch the #3 plug to another hole, if the code follows, you will know it is a bad plug, they will warranty it. If it doesn't change do a compression and if need be a leak down on 3 to verify condition of the valves.
Knighted
Nov 18, 2014 06:25 AM
film842
Nov 1, 2014 06:56 AM
Ad!
Nov 28, 2011 10:06 PM
gfeehan
Sep 1, 2008 09:41 AM
gfeehan
Aug 29, 2008 08:44 PM
